What are the most successful resolutions to the codes that are associated with malfunctioning oxygen sensors/ heaters resulting from long tube header/ cat deletion modifications?
The specific code P0141 Heated Oxygen Sensor (HO2S) Heater Circuit Bank 1 Sensor 2 is what I am trying to resolve.
Thanks for any help....
Sensor 2 is the rear O2 sensors after the cats. If you take the cats out, then you will get multiple errors from the rear sensors. Won't effect performance, but more of an annoyance.
2 options..
1. Get Rear O2 simulators.
2. Get them Tuned out from someone that has tuning software.
2 options..
I appreciate the responce, I'll give the simulators a try.
