Auto shift points on a Predator?
load the Performance Tune, then set
global rev limiter: 6200
shifting pressure (firmness) : +10%
shifting speed (quickness): -10%
timing: advance 3%
1-2; 2-3; 3-4 WOT shift RPM: 6000
1-2 WOT shift MPH: take your C5 A4 and place the gear selector in "1". Run the car up to 6000 and note the MPH at 6000 RPM. then enter the 1-2 WOT MPH shift @ 2mph below your finding.
2-3 shift MPH: take your C5 A4 and place the gear selector in "2". Run the car up to 6000 and note the MPH at 6000 RPM. then enter the 2-3 WOT MPH shift @ 2mph below your finding.
I started w/ this set-up, then I went to 6100 rev limit up, 6000 down
shift rpm: 5800
1-2 at 40 mph
2-3 at 75 mph
because the A4 won't upshift at WOT until both mph and rpm limits are reached...this way the low mph's are hit before the 5800 and the A4 upshifts arount 5800
I have not had a duno tune yet as I'm not done with my mods. But if I understand correctly, a good tuner can do everything the Predator can do plus much more. Hopefully, someone with more knowledge with this will chime in.
Clayton
shift rpm: 5800
1-2 at 40 mph
2-3 at 75 mph
am now happier w/
rev 6250 up/ 6150 down
shift rpm: 6000 all gears
1-2 at 44 mph
2-3 at 84 mph
shifts at redline everytime WOT w/out hitting rev limiter
