C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Are files interchangable between software programs?
Old Feb 6, 2006 | 09:30 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Default Are files interchangable between software programs?
For example, if I have HPTuners and I want to put file in from LS1Edit does that work? Do they all write the same format? Thanks!
Old Feb 6, 2006 | 09:50 PM
FixedRoof's Avatar
FixedRoof
Cruise-In VI Veteran
No, well kinda sorta.. LS1Edit can read HP tuners bin files. Doesn't seem to work with 1998 files though. HP Tuners, can't read LS1 edit files. EFI Live can also read HP tuners files as well...
You can open them and use them for reference..
steve
Old Feb 7, 2006 | 06:50 PM
Nithros's Avatar
Nithros
St. Jude Partner since 89
St. Jude Donor '09
To add to what was previously said - the new (2.x) version of HP Tuners writes out files that are proprietary and cannot be read by those mentioned previously.
Old Feb 13, 2006 | 11:38 AM
billiardcue's Avatar
billiardcue
Can EFILive read LS1edit files?
Dick Abbott
Old Feb 28, 2006 | 05:30 PM
1998ws6370's Avatar
1998ws6370
no software can read other software's encrypted file format. .ls1 for ls1edit, .hpt for HP tuners V2.0+ and the .tun for EFI live's format.
HPtuners old .bin file could be opened with other software packages, but they went away from this open source format..
However, once the file is flashed to a vehicle, as long as the pcm is not "locked" then you can read it with your tuning software of choice.
Old Mar 1, 2006 | 12:20 PM
zmike6's Avatar
zmike6
If I have a custom tune in the PCM, (done using LS1 Edit or HP Tuners or whatever), can I use a Predator to save that tune on my PC? And maybe send a copy of that tune to someone else, to install using a different Predator?
Basically I'm wondering if the Predator can be used to capture and distribute tunes that were originally created with other software.
Old Mar 1, 2006 | 06:38 PM
see5's Avatar
see5
You can pull any tune from the PCM and read it with any of the software programs.
Old Mar 2, 2006 | 07:37 AM
Nithros's Avatar
Nithros
St. Jude Donor '09
Correct as long as it was not locked by the previous tuner (as originally posted by 1998ws6370). Also, you must have purchased the software for the model year and platform you are tuning with at least some of the packages.
To Are files interchangable between software programs?
