C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Need Tune after Headers?
Old Mar 9, 2006 | 09:59 PM
dhpeck's Avatar
dhpeck
Default Need Tune after Headers?
Advise on whether I need Tune to get full power after Header Install
Old Mar 9, 2006 | 10:16 PM
DTSNGIT's Avatar
DTSNGIT
Yes you will need a tune to realize full power after any header install.
Mike
Old Mar 9, 2006 | 10:53 PM
dhpeck's Avatar
dhpeck
Thanks for the Advise: Is there such thing as a tuner Directory or will we drive hundreds of miles for a couple rwhp? I'm up in Wisconsin!
Old Mar 10, 2006 | 11:06 AM
BudgetPlan1's Avatar
BudgetPlan1
St. Jude Donor '09-'10
May wanna try a post in the regional forum to see if folks in your area have any suggestions:
http://forums.corvetteforum.com/forumdisplay.php?f=43
Old Mar 10, 2006 | 01:25 PM
Sorny's Avatar
Sorny
Try Doug Rippie Motorsports in Buffalo MN. Very well known tuner.
Not sure where you are in WI, so I don't know if that is a long trip for you or not.
Sorny
Old Mar 10, 2006 | 02:12 PM
dhpeck's Avatar
dhpeck
thanks it's getting closer! I'm in Green Bay, Can't believe anyone in Wisconsin doesn't want to drive faster.............
Old Mar 10, 2006 | 04:49 PM
fdxpilot's Avatar
fdxpilot
Lots of tuners down near Chicago.
Old Mar 11, 2006 | 06:08 PM
UVETTYA's Avatar
UVETTYA
Yes.
Do you mind if I ask... did you set any codes after the install? Which year/engine do you have, is it stock, and which headers did you install?
Steve
Old Mar 25, 2006 | 01:05 AM
Chalky's Avatar
Chalky
St. Jude Donor '08-'09-'10
There is a guy named Brian Volper, not sure on spelling but he is mobile and does tuning in Milwaukee using the dyno @ Borchardts. There is also a place just south of GB , a truck stop that has a dyno jet. Brian has also driven up there to tune as well. Brian is out of Chicago so you may pay to have him drive very far north.
Contact See5 on the CF. He can provide more info on the dyno and Brian.
If you end up dynoing in Milwaukee, fill your tank in GB. We have the RFG gas in this area.
Old Mar 27, 2006 | 10:04 PM
dhpeck's Avatar
dhpeck
I'm having Melrose Headers installed so I don't know what will happen with codes. Using a shop that does alot of vette work, hoping they know how to deal with codes
I've got a 6spd 01 coupe that is stock. Just added corsa pace car and black wing and hurst shifter though....
Old Mar 27, 2006 | 10:11 PM
Chalky's Avatar
Chalky
As long as you don't get any air leaks, you should be OK. Even if you throw a code, you can clear them using your DIC.
Old Mar 28, 2006 | 10:48 AM
Gordy M's Avatar
Gordy M
Check with the shop that is doing the install, see if they at least have scan log software. If so, do a 20-30 minute run with the software running, they can tell if you have any shortcomings and what they are. The usually have to do with idle, acel/decel and timing or AF ratio's. If they are noticiably off, you can send this info to a good tuner with your PCM and they can program a respectable tune for you. With Overnight Fed EX, you can send it anywhere in the US and have it back within 3 day.
Once you get it tuned, you need to put at least 200 mile on the car to get the maximum benefit.
Old Mar 28, 2006 | 03:24 PM
BuffC5's Avatar
BuffC5
A full tune will make the most available power out of all your mods. If you want the most power, tune, tune tune.
To Need Tune after Headers?
