C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Flashed Computer????
Old Apr 3, 2006 | 08:55 AM
Z06Joe@AutoBuffs's Avatar
0Z06Joe@AutoBuffs
Former Vendor
St. Jude Donor '08-'09-'10
Default Flashed Computer????
I have a question for the all mighty forum. I had the fuel gauge issue where it was misreading saying it was near empty when full and vice versa. Well I took it to the dealer and they said the fuel sending unit was bad, so they replaced it. However I am wondering if they would have need to update the computer in the car, because I went out crusing Saturday night and was in a downtown setting were the car normally gets no hotter than 190, with the 160 thermostat, however it reached 225. And that leads me to believe they flashed my computer and reset my fan's to come on at the factory settings.
If this is true, will I basically be SOL with my programmer? Or will I be able to reset the fans and restore the performance tune setting?
Any info/feedback will be greatly appreciated.
Thanks.
Old Apr 3, 2006 | 09:34 AM
Gordy M's Avatar
Gordy M
If there were any outstanding recalls for your car that required a PCM flash or update the dealership has to do it unless you opt out in writing. You probably had the column lock recall flash done and wiped out your old calibrations.
Old Apr 3, 2006 | 09:36 AM
0Z06Joe@AutoBuffs
Former Vendor
So my next question would be if my stuff got wiped out, will I be able to use the Predator Programmer to reset them or does the programmer end up becoming a paper weight?
Thanks for the quick response btw.
Old Apr 3, 2006 | 10:35 AM
Mike Mercury's Avatar
Mike Mercury
there may be a way out of this; but you need to call Johan @ Diablosport. If anyone knows for certain... it would be him.
To Flashed Computer????
