C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Spark Plugs..
Old Apr 25, 2006 | 03:43 PM
SLPRC5's Avatar
SLPRC5
Default Spark Plugs..
Are the new AC/Delco Iridium Professional spark plugs better than the NGK TR6 plugs for daily driving?
Thanks,
Rsty
Old Apr 26, 2006 | 04:21 AM
0rion's Avatar
0rion
First off let me say that this is just my opinion. Unless you're spraying or running FI most people run the TR55's instead of the TR6's. My opinion is spark plugs now days are leaps and bounds above what they used to be. I feel you pretty much can't go wrong with any good named plug. You'll normally get tons of miles out of just about any plug. On my cars I tend to stay away from overly expensive plugs and keep it simple and basic. I never have issues with plugs but like I said this is all just my opinion.
Old Apr 26, 2006 | 09:33 PM
SLPRC5's Avatar
SLPRC5
Than you Orion..you opinion is valuable...I'm going back to the Iridum plugs.
Old Apr 28, 2006 | 12:52 PM
c5chris's Avatar
c5chris
I went with NGK TR55s. For $20, I have no problem changing them after a few thousand miles. To me, Im uncomfortable with running plugs over 100K. GM used them just because they last longer and the LS1/LS6 has really bad placement of some of the plugs.
Iridiums or TR55s, I dont think anybody can go wrong. I own turbo cars and Im just comfotable with good old copper cores. Platinum and Iridium may be OK but I'll stay with the copper ones.
Old Apr 28, 2006 | 02:28 PM
Anti-Ford's Avatar
Anti-Ford
SO which is cheeper, the TR55's or the stock double Platinum PZTR5A-15 ?
Old Apr 28, 2006 | 04:27 PM
hex's Avatar
hex
The TR55's. They range from $1.50-$3.00 each. My opinion is to run them 15-30k anyway, so that's what I use on normally aspirated apps, and TR6 on boosted or nitrous apps. I run .050" on the 55's, and .032-.035 on the TR6's, in a power adder app.
Using the iridiums or platinums are fine on any normally aspirated application, albeit more expensive.
Old Apr 29, 2006 | 01:35 AM
SLPRC5's Avatar
SLPRC5
Thanks for your input. Today I changed to the Iridium plugs and right off I could feel the SOTP response. I like the idea that the Iridiums are good up to 100K..
Thank everyone for their input.
Rsty
Old Apr 29, 2006 | 06:38 AM
see5's Avatar
see5
Seems like the TR6s will remove 3-4 degrees of KR.
Old Apr 30, 2006 | 12:39 AM
SLPRC5's Avatar
SLPRC5
Tuner advanced my timing2 degrees for cruising speed 80+ mph with the TR6 plugs...what is KR???
Thanks,
Rsty
Old Apr 30, 2006 | 01:38 AM
hex's Avatar
hex
Knock Retard. I have not seen the different designs of spark plugs cause them to either advance or retard. If you have a nasty old set in there, and you put some new ones in, the knock retard you may have had with the old nasty plugs will go away. I have only seen this in extreme cases, like the one that had 5-90k plugs, and 3 splitfires in one engine. A new set of TR55's, and it was as if it was tuned again.
Old Apr 30, 2006 | 06:56 AM
see5's Avatar
see5
Thanks,
Rsty
The TR6s are a slightly cooler heat range. If your timimg s not over advanced and/or your compression is not too high you may no have knock retard. You will have to scan to find out.
To Spark Plugs..
