C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
MAFless IAT
Old May 15, 2006 | 09:42 AM
billiardcue's Avatar
billiardcue
Default MAFless IAT
How do you register IAT if you unplug the MAF?
Dick Abbott
Old May 15, 2006 | 10:30 AM
xlr8shn's Avatar
xlr8shn
Run the earlier setup where IAT and MAF are separate...
The IAT on my 99 is between the "A" and "B" arrows.
Old May 15, 2006 | 10:55 AM
John@SDPC's Avatar
0John@SDPC
Former Vendor
Do you want to remove the MAF, or are you just trying to do some SD tuning work?
If removing, then you will need a separate sensor for the IAT (like a pre 2001 vette). If just trying to perform SD tuning, then you can set the MAF fail frequency to 1. Confirm that the PCM is registering P0101, P0102, or P0103. This will ensure that the PCM is using the VE table vs. the MAF.
Old May 15, 2006 | 11:29 AM
billiardcue
SD tuning.
I set the MAF fail rates to 1 as instructed in the EFILive tutorial but the next step tells you to unplug the MAF and to make provisions for reading IAT.
Old May 15, 2006 | 01:12 PM
Darkness's Avatar
Darkness
http://www.ls1tech.com/forums/showthread.php?t=506846
Old May 15, 2006 | 02:40 PM
John@SDPC's Avatar
0John@SDPC
Former Vendor
Originally Posted by billiardcue
SD tuning.
You don't have to unplug. They really need to update the tutorial. Here is another link with good info on the subject.
To MAFless IAT
