noob question
AI - Alcohol Injection
AFR - Air Fuel Ratio
DFCO - Deceleration Fuel Cut Off
ECT - Engine Coolant Temperature
ETC - Electronic Throttle Control
IAC - Idle Air Control
IAT - Intake Air Temperature
IFR - Injector Flow Rate
KR - Knock Retard
KPA - Kilopascal (metric pressure measurement)
LTFT - Long Term Fuel Trims
MAF - Mass Air Flow (Sensor)
MAP - Manifold Absolute Pressure
PE - Power Enrichment
SD - Speed Density
STFT - Short Term Fuel Trims
TPS - Throttle Position Sensor
VE - Volumetric Efficiency
VSS - Vehicle Speed Sensor
WOT - Wide Open Throttle
I'd go over to LS1Tech and read some the stickies there.
http://www.ls1tech.com/forums/forumdisplay.php?f=7
