C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Low octane table
Old Jun 5, 2006 | 03:32 PM
Jserman's Avatar
Jserman
Default Low octane table
I am using Hptuner
I am running meth injection on my S/C car.....This map is in the high octane table
I put my map before the meth in the low octane table just incase the meth failed it would go back to low octane mode and the car would be fine..
it seems the car is stuck in low octane mode because my methe failed is there a way to get it out of it... or reset it or check it out anything..
help apprecaited
Old Jun 5, 2006 | 06:36 PM
muncie21's Avatar
muncie21
Map? Are you referring to the timing table? If you are stuck in the low octane table, just copy the values from low to high. The PCM starts to blend low octane with high when it sees knock. The more knock, the more it blends until you are running completely in the low table.
If you don't want to copy the high table to the low, then do some driving until the knock learn resets itself.
