C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
"OVERTEMP" for split second, need help!
Old Aug 3, 2006 | 09:08 PM
GOTT C5's Avatar
GOTT C5
4th Gear
Default "OVERTEMP" for split second, need help!
While driving my stock 32,000 mile 97' the DIC shows "OVERTEMP", then reduces power for a second. This has been happening for a while, then stops but recently started again and does it more often. The digital and analog coolant gauge both go well above 220 degree then right back to normal. I have replaced the coolant sensor and thermostat with no luck. I think its air in the system, I don`t know.
The P0117H code came up, wondering if I`m the only one. Not driving it anymore until its fixed.
Old Aug 3, 2006 | 09:51 PM
hex's Avatar
hex
have to determine if it is really overheating, first.
Old Aug 12, 2006 | 10:02 PM
GOTT C5's Avatar
GOTT C5
4th Gear
I found a wear spot in the yellow wire coming from the coolant sensor. It was located where the two sensor wires meet the larger harness. It appeared to be rubbing against the alternator bracket.
I covered it and stated the car, then guages went an stayed right to red, then sliced out bad part of yellow wire, went right to red again. I unplugged sensor and started the car and guages did same thing. I ordered new sensor, it should be here any day now. I`m eagar to get it in.
Old Aug 18, 2006 | 12:06 PM
GOTT C5's Avatar
GOTT C5
4th Gear
Problem fixed, ended up being sensor wire that rubbed the bracket so much it wore through and messed with the guage readings.
To "OVERTEMP" for split second, need help!
