C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
WB emulating NB
Old Sep 23, 2006 | 11:28 AM
molson's Avatar
molson
Default WB emulating NB
I am going to run a WB in the pass side stock location using it for a NB as well....
I need to know what the 4 wires that come from the stock harness do.
pin A is Tan = heated o2 low
pin B is Purple = heated o2 high
pin c is Black = ground.
pin d is Brown = switched 12v.
The brown goes to LC-1 red
The Black goes to LC-1 Blue.
The purple goes to LC-1 yellow
The tan goes to LC-1 green.
Car is a '98 vette....
I am not sure how to wire the LED..Which is ground red or black??
Does it need a seperate ground or can I use the white chassis ground?
does the switch/light go in the cabin?
The brown wire is the only wire I need to connect to my interface?
Old Sep 25, 2006 | 11:33 AM
muncie21's Avatar
muncie21
You'll need to connect the brown (high) and white (low) to your interface. It's best to mount the LED in the cabin. The LED will blink to show trouble codes, which is useful to see while you are in the car.
Old Sep 25, 2006 | 01:05 PM
cjs27410's Avatar
cjs27410
Lots of good info at this website!
http://www.innovatemotorsports.com/forums/index.php
To WB emulating NB
