C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
BCM read/write
Old Jan 6, 2007 | 12:44 PM
huttler's Avatar
huttler
Default BCM read/write
What do you guys think about being able to read/write to the BCM? The owner of HPtuners, Ken, on the VCM suite features request forum forum has shown a bit of interest to the idea. However, he is going to need to know that people would buy it. I know as a C5 owner that I deeply crave the ability to edit the BCM settings so I don't have to rely on the dealer to disable my CL, or bleed the ABS system amoung many others. Hope to see some input over there!!
Old Jan 6, 2007 | 03:29 PM
thehammer69's Avatar
thehammer69
I thing this is an excellent idea...it should enable people to remove the cut fuel at 2mph feature that is getting programmed into the BCM as part of the Collumn Lock recall.
Hammer
Old Jan 7, 2007 | 04:55 AM
Corvette4ever's Avatar
Corvette4ever
What parameters we'd be able to change if we have access to the BCM?
Old Jan 10, 2007 | 02:16 AM
huttler's Avatar
huttler
As previously mentioned, the column lock 2mph fuel shutoff BS, BCM error codes edit and clear, ABS bleed, tire pressure monitor, that is all i can think of off the top of my head, but anything the BCM controls would be fair game.
Old Jan 10, 2007 | 01:33 PM
molson's Avatar
molson
....and I could ditch my F-45 and twilight sentinal.
Old Jan 15, 2007 | 11:10 PM
BLOWNZO6's Avatar
BLOWNZO6
Premium Supporting Vendor
I would be interested as well.
Pricing would be the critical thing.
If you could, for example cure the CLB issue, it would be worth $50, but for the most part it would be a hard sell.
Old Jan 21, 2007 | 06:20 PM
69's Avatar
69
Cruise-In VI Veteran
Anything that lets me crack into the modules to troubleshoot failure codes is a good thing!
Old Jan 22, 2007 | 08:10 PM
shihiran's Avatar
shihiran
where is the bcm located and how much will it cost to get fix.
To BCM read/write
