I have a LC-1 installed in place of my narrow band 02 on my drivers side (before the X pipe). The question is should I spend the extra $ on a second one to monitor the passenger side? I have the LC-1 perminately installed, simulating a narrow band and don't want to go throught the hassel switching it from side to side.
What are the thoughts on monitoring both banks, it it a good idea?
The PCM averages out the fuel trims, so my suggestion, unless you're a perfectionist, is to use just one. You've got it on the normally lean side of the engine, so if the driver's bank is okay, the other side is too.
Agreed.
I could see having bungs on both sides perhaps but the complexity of two sensors is a bit much. The really hard core engine dyno guys have on on each cyl for R&D.
