C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Mailorder BCM programming
Old May 7, 2007 | 09:13 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Default Mailorder BCM programming
Anybody have the capability to program a BCM on the bench?
I don't want to flatbed my car to a dealership for this unless I absolutely have to.
Old May 7, 2007 | 08:59 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
TTT, btw I'm located in Memphis
Old May 8, 2007 | 12:02 AM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Default Bcm Programming.....
Hey man.... I'm not sure, but...I'd be willing to try......I know I can program it.....I'm not sure however if it would work.....When Programmed, it mates itself to the pcm by vin and your anti-theft system may not permit the vehicle to start.....
I have many vettes here and if you sent it to me It could be installed in another car and programmed by RPO code....but, I think the only way to make it work would be to send the pcm as well and have the anti theft system disabled.
The best idea is a dealer or a repair shop with a Tech II or someone with an EFI live cable to do a vats re-learn....
I could try..but, I'm not sure if it would work....All these computers talk....They are like old wives.... If there's a mis-communication...There's gonna be trouble.
Call me if you like.
Chuck CoW
Old May 8, 2007 | 07:13 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Chuck CoW
Thanks, I'm leaning towards a flat bed to the dealership.
Thats probably the smart thing to do anyways since I also installed a new SDM and PCM and none of these are recognizing each other right now.
I was hoping to have the car running before I started my body work though.
Old May 8, 2007 | 09:48 AM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
Default Yeah, looks that way.....
That sounds like the best idea...I I could get to you with my tech II or efi live I could probably fix it, but....I too think the dealer is a better choice..
Chuck CoW
To Mailorder BCM programming
