C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Code PO137???
Old May 21, 2007 | 08:59 PM
PugLover's Avatar
PugLover
Default Code PO137???
Code comes on about every 3 days. I have an after market exhaust. Any idea what I can check before I take it to the shop. Any help would be GREATLY appreciated.
Mark
Old May 22, 2007 | 12:52 AM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Code P0137 is for the REAR 02 sensor on the driver's side-- Typically these codes are associated with header installs---But since it ony is on the one side I would look for an exhaust leak somewhere on the driver side---Or an unpluugged or fouled rear sensor or broken wires---If you can't get it resolved it is an easy fix for a tuner to disable the rear 02's or you can purchase 02 simulators for the back---
Old May 22, 2007 | 05:21 AM
PugLover's Avatar
PugLover
Default Thanks for the reply but
Where is the 02 sensor located.
Mark
Old May 22, 2007 | 05:27 PM
tblu92's Avatar
tblu92
The rear 02 sensors are located in he middle of the car just past the Catylitic converters--there are 2 of them --side by side--just in front of the rear axle transmission assembly
To Code PO137???
