C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
code C1225
Old Jun 11, 2007 | 09:07 PM
Vette Ed's Avatar
Vette Ed
CI 4-5-6-7-8-9-10 Veteran
St. Jude Donor '07-'09
Default code C1225
what is it and what is the fix.
The book says, Excessive Wheel Speed Variation.
Old Jun 11, 2007 | 09:52 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
C1225 is a code for the Left front wheel sensor---It sends information back to the computer that controls the ABS brake system & traction control.The visual repair is usually a disconnected sensor wire or broken wire.Other than that it can be a faulty sensor--dirt or rocks or debris on the reluctor wheel ring or a false or isolated one-time code----Also i checked a few manuals and 2 of them said left front and one said right front--so i would check both sides.
The sensor is located just behind the brake rotors--follow the wires that go to the wheel and it is right there---the reluctor ring is located on the brake rotor usually------
Old Jun 11, 2007 | 10:11 PM
Vette Ed's Avatar
Vette Ed
Thanks for the fast reply
To code C1225
