C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
IAT Question ??
Old Jun 17, 2007 | 12:55 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Default IAT Question ??
My 2001 Corvette Coupe w/auto had a magnuson SC installed on it.
They removed the IAT sensor completely. Can anyone tell me why they did this ?
I have since removed the maggie and re-installed an LS6 manifold with stock injectiors. I plan to run a halltech stinger, would you re-install the IAT ?
Old Jun 17, 2007 | 11:36 AM
SSpdDmon's Avatar
SSpdDmon
Yes.
If you're going back to a manifold setup, you'll want to have the tune re-adjusted too. Otherwise, it'll be quite rich...
Old Jun 17, 2007 | 11:50 AM
Scoundrl's Avatar
Scoundrl
There are tables in the tune to add or pull timing based on the IAT. The reason it gets remove is that the IAT is changed when you compress the air. The tune would pull timing because of the high IAT. My IAT table is blank because my car was pulling timing when the car go hot and heated up the sensor giving it a bogus reading. My climate is pretty steady here and no need to pull timing based on the temperature.
Take care,
-Ken
Old Jun 17, 2007 | 12:14 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Take care,
-Ken
Ken,
Thanks for info. I always here turbo and SC guys talking about IAT tempertures. That was why I was wondering why tuner removed mine. Makes sense now.
Thanks,
Tony
Old Jun 17, 2007 | 10:26 PM
Kviper's Avatar
Kviper
Sorry to highjack this but I have done many searches for a 2001 IAT- but where is the thing located? Its not in my my stock airbridge or surrounding area. Do I have to pull that ugly contraption they call a stock airbox out? Thanks!
Old Jun 17, 2007 | 10:29 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Your IAT should be on your airbridge, drivers side.
If it's not there then more than likely it was removed by someone.
Old Jun 17, 2007 | 10:52 PM
Kviper's Avatar
Kviper
I just found a thread that says for 2001 its integrated into the MAF. That would explain why when I shot it with cleaner 2 months ago the pinging went away for a few days- I am trying to stop the pinging in this Nevada heat without having to get a tuner right now
Old Jun 17, 2007 | 11:26 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Thanks, I did not know it was in MAF for 2001's.
That's funny, because my other 2001 coupe had a it in the airbridge. It was early 2001 that was made in July of 2000.
Old Jun 18, 2007 | 02:19 AM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
The IAT as mentioned adds or removes timing based on Intake air temperatures--It has nothing to do with fuel mixture --rich or lean--many tuners (including myself) delete the entire table--As under normal operating conditions it subtracts up to 7 degrees timing unneccesarily-the IAT sensor is a good idea however it usually reads underhood temps or airbridge temps which are not actual AIR intake temps--What happens is that the undehood temps transfers to the IAT mistakenly and you get a false reading--Another reason for getting rid of the table is to elimonate any timing surprises when doing performance tuning--When you dial is 28* timing --you will get 28* timing--there will be no subtractions--makes for more accurate tuning-
Another table that is similar that many tuners delete is the coolant temp table--same principal applys here--No surprises or subtractions--The coolant sensor however is accurate--but GM takes out way to much timing in respect to higher coolant temps--as low as 200* it starts to subtract timing--
Old Jun 18, 2007 | 10:14 AM
Kviper's Avatar
Kviper
Thanks for the responses! Sounds like I need a tune/tuner
Old Jun 20, 2007 | 06:02 PM
INTHERED's Avatar
INTHERED
I can't imagine any good tuner completely removing the IAT table. I have a 2000 C5 with a Maggie and in 75 degree weather my tune is right on the money while in 85 degree weather it knocks its butt off.
I think a better approach is to relocate the IAT sensor in combination with editing the IAT table so that the IAT sensor does the job its intended to do giving you the proper timing for variations in the weather. Yea GM is a bit conservative with the IAT table but thats no excuse for zeroing it out. Take the extra time and edit it for the intended application.
INTHERED
Old Jun 20, 2007 | 06:53 PM
Scoundrl's Avatar
Scoundrl
If GM was so smart about it they would have put it in a proper place and had it be and IAT sensor instead of a partial under hood partial IAT sensor. This table was also not designed for forced induction applications where there will be large temp variations while under and not under boost. I have seen plenty of tunes by competent tuners with this table zeroed out, because the table is not intended for use in some of these applications. If you are having that much knock occur with only 10^ air temp difference maybe you should have one of those competent tuners take a look at yours. Zeroing out the table has virtually no effect on drivability or reliability if the tune is solid and there are not HUGE temperature differences. AFR is much more important and is well taken care of by the rest of the tune.
-Ken
Old Jun 20, 2007 | 10:52 PM
SLPRC5's Avatar
SLPRC5
I relocated my IAT from the air bridge to the head of my Blackwing next to the sensor monitor and it appears to work well.
Old Jun 21, 2007 | 12:56 AM
Dirty Howie's Avatar
Dirty Howie
The IAT can also add or remove fueling. I use this table to add fuel to prevent detonation at high ambient temps. My IAT/SPARK table is zero'd so I don't loose any timing.
May not be right but it works for me........
DH
Old Jun 21, 2007 | 11:24 AM
INTHERED's Avatar
INTHERED
If GM was so smart about it they would have put it in a proper place and had it be and IAT sensor instead of a partial under hood partial IAT sensor. This table was also not designed for forced induction applications where there will be large temp variations while under and not under boost. I have seen plenty of tunes by competent tuners with this table zeroed out, because the table is not intended for use in some of these applications. If you are having that much knock occur with only 10^ air temp difference maybe you should have one of those competent tuners take a look at yours. Zeroing out the table has virtually no effect on drivability or reliability if the tune is solid and there are not HUGE temperature differences. AFR is much more important and is well taken care of by the rest of the tune.-Ken
Maybe in your state you can get away with zeroing out the table but here in Maryland my car sees a temperature swing of 20 to 100 degrees F. Unless you go with different tunes for hot and cold weather editing the IAT table is the only way I can get maximum performance under a variety of conditions
INTHERED
Old Jun 23, 2007 | 03:22 PM
American Hydrocarbon
Guest
Posts: n/a
Is that Maggie for sale? I have an auto 2000.
Old Jun 23, 2007 | 05:14 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Sorry Maggie was sold a few weeks back.
To IAT Question ??
