C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Hypertech Tuners
Old Jul 7, 2007 | 09:43 AM
Gene Moses's Avatar
Gene Moses
Default Hypertech Tuners
Is there any one with experience in Hypertech Programmer III's in Vancouver, Canada or as a second choice the Seattle area. The program has been installed but I am not convinced it is up and running at its best. Thanks
Old Jul 15, 2007 | 06:00 AM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
you didn't say what kind of car you have--i'll assume a corvette or camaro--There isn't much left on the table from GM on a corvette--10-15 RWHP at best----a camaro--somewhat more maybe 17-20---Other than setting the fans--and with an automatic setting the shift points up higher there isn't much more a hypertech can do--also some have dual fuel settings for maximum timing--but even that is questionable because the higher setting is designed around 93 octane fuel--amd many states like calif only have 91 octane and that setting just pings all the time
