C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Which Wideband??
Old Jul 31, 2007 | 11:13 PM
RIP1976's Avatar
RIP1976
Default Which Wideband??
I'm looking to buy a wideband for use with my HPT Pro and was pretty much set on the LM-1 but do I need any of the add on stuff they sell to go with it?? Also I'm planning on useing the wideband between a couple different cars and would like to have something easily swapped between the cars but if I have a O2 bung welded in the exhaust of the cars that is easy to get to is the LM-1 any easier to swap around than any of the others such as the LC-1? The recording feature in the Lm01 I don't think will really be something I see as using much since I have the pro hpt and can easily use the scanner to record everything I wanna see.
Any advise an especially experiance would be greatly appreciated and .
Old Jul 31, 2007 | 11:22 PM
hex's Avatar
hex
Any advise an especially experience would be greatly appreciated and .
LM1, but you only need it to see if you have a problem on a run. Too many LC1's being inaccurate, having problems with the cable. Even with the lm1, you need to verify accuracy(and make adjustments to the cal for the htp cable), so understand that it is not an entirely plug and play deal.
Old Jul 31, 2007 | 11:47 PM
RIP1976's Avatar
RIP1976
Yea I have read the LM-1 setting in the hpt is not correct and has to be changed before even useage.
To Which Wideband??
