Check engine light on
Aug 18, 2007 | 10:12 PM
St. Jude Donor '12-'13-'14
Beautiful night at 70 degrees so I took the wife on a dinner date.
Driving home the check engine light comes on. I pulled the codes and im PO 0172 and 0175 im rich in bank 1 and 2.
Last week I uploaded a richer tune and I guess it worked. I just uploaded my leaner tune, and cleared he codes.
How do I shut off the check engine light with my HP tuner.
thanks
Phil
Aug 19, 2007 | 06:30 AM
Quote:
Originally Posted by
phils C5 vette
thanks
Phil
Phil...I remove my codes with my OBD II & that always turns off the CEL...??? If you have one, try a OBD II . Bill T
Aug 19, 2007 | 07:10 AM
I removed the codes last night with HPTuners, and the check engine light was still on. I did not start the car again.
Acutally I tried, but the car would start because of a little problem Im having with the clutch safety switch.
Aug 19, 2007 | 09:11 AM
I got the bucket of bolts to start this morning and was able to shut off the check engine light.
I need to replace my neutral safety switch
Aug 21, 2007 | 05:17 PM
How do I clear check engine light. I pulled the PCM fuse, #16 and no help. Advise and thanks. Dave
Aug 24, 2007 | 12:27 PM
Just can't leave it alone can you?
Aug 26, 2007 | 09:56 AM
Im in a ten step recovery process now
1) buy a beautiful stock car
2) put on exhaust
3) bolt ons
4) cam
5) another cam, heads, clutch
6) another clutch and 3.90s
7) another cam and another intake
8) TBD
9) TBD
10)TBD
Aug 26, 2007 | 12:28 PM
phils C5 vette
2) put on exhaust
3) bolt ons
4) cam
8) TBD
9) TBD
10)TBD
Sounds about right...
