C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Traction control delete
Old Oct 16, 2007 | 05:05 PM
Doug@MorosoPerformance's Avatar
0Doug@MorosoPerformance
Former Vendor
Default Traction control delete
Asked this question in tech, never got a good answer. Can the traction control be permanently turned off on a 1999?. I want to keep the option of being able to turn the A/H on or off.
Old Oct 16, 2007 | 07:09 PM
lar66BB's Avatar
lar66BB
Default traction control
Seems I have heard before that you can not turn it off. But that
is only from memory and I'm getting old.
Old Oct 16, 2007 | 09:15 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
In addition to the obvious ( turning the TC button off) there are many traction control files in the ECM ---There isn't an entry to just disable it but what i see is that the TC system uses the spark retard tables or knock retard to remove power from the engine when it senses a loss of traction from spinning--typically it removes around 10-25* of timing depending on RPM and a few other parameters--You can enter "0"s into all those tables and when the system becomes active it won't remove ANY timing--Have never tried it but quite sure it would work--
Old Oct 16, 2007 | 10:38 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
You can set the PCM to retard 0* timing during TC engagement easy enough...but the problem is, if the EBCM still senses wheelspin after commanding the timing retard to the PCM, it activates the rear brakes.
Old Oct 17, 2007 | 02:24 AM
IM28702's Avatar
IM28702
Default Tc...
There is a product called Laptrax that will auto disable the TC and AH, as if you flipped the switch yourself. http://www.laptrax.com/ I intend on buying one in the very near future as I HATE the TC n my car. It will also auto set Competition mode, which is what I think you're looking for, and then you can still hit the switch to cycle manually through on off or comp mode.
Old Oct 17, 2007 | 09:59 AM
Former Vendor
Thanks.
Changing the spark retard table would solve one problem, but I believe that the ecm reduces the throttle angle before or after applying the brakes. I will give the LAPTRAX a try, they were on sale last week for $35
Old Oct 17, 2007 | 02:43 PM
JR-CRUZN-C5's Avatar
JR-CRUZN-C5
I have a LAPTRAX it works perfect - set it to off and at the startup your TC is off - push the consol button to turn it on!!
JR
To Traction control delete
