throwing po410 code. reset and comes back. stock 1998 auto, 51,000 miles, no mods. Any ideas on what to check. Whats possible causes and fixes. Thanks.
I installed headers and an off road Xpipe last week. I had the same code. When I did the install I disabbled the air system. Thats what that code goes to.
Just have your tuner disable it.
Matt
P0410 is a code for the secondary air injection system--The air pump that pumps air into the exhaust to clean emissions ...check the intake hose that is on the air cleaner to see if it is on proprerly--check for any exhaust leaks--check the check valves on boths sides--they do carbon up sometimes and won't shut---also check all the air line connections on the driver's side to see if any of the hose clamps broke or hoses are bad--otherwise it may be a random code---have it cleared with a scanner and try again--
I had this code and tried the pump fuses and relays - no change. Finally found a used pump and when I pulled mine out to swap saw that the pump valve mechanism was trashed. Looked like it just dried out. That fixed it though.... Good luck...
