C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Proper Compression?
Old Dec 19, 2007 | 06:57 PM
Fasttimes73's Avatar
Fasttimes73
Default Proper Compression?
Hey everybody,
I am going to check compression on my 2000 FRC this weekend, just wondering what it should be registering? Any feedback would be greatly appreciated!
Old Dec 19, 2007 | 08:16 PM
jodfit's Avatar
jodfit
St. Jude Donor '07
Old Dec 28, 2007 | 02:54 AM
RED99's Avatar
RED99
I wouldn't worry about the cylinder pressure as much as the differential between the cylinders.
Old Dec 30, 2007 | 06:41 PM
ILM-Express's Avatar
ILM-Express
MFIC
Engine Compression Test
Charge the battery if the battery is not fully charged.
Disable the ignition system.
Disable the fuel injection system.
Remove all the spark plugs.
Turn the ignition to the ON position.
Depress the accelerator pedal to position the throttle plate wide open.
Start with the compression gauge at zero and crank the engine through four compression strokes, 4 puffs.
Check the compression for each cylinder. Record the readings.
If a cylinder has low compression, inject approximately 15 ml (1 tablespoon) of engine oil into the combustion chamber through the spark plug hole. Recheck the compression and record the reading.
The minimum compression in any one cylinder should not be less than 70 percent of the highest cylinder. No cylinder should read less than 690 kPa (100 psi). For example, if the highest pressure in any one cylinder is 1 035 kPa (150 psi), the lowest allowable pressure for any other cylinder would be 725 kPa (105 psi). (1 035 x 70% = 725) (150 x 70% = 105).
Normal -- Compression builds up quickly and evenly to the specified compression for each cylinder.
Piston Rings Leaking -- Compression is low on the first stroke. Then compression builds up with the following strokes but does not reach normal. Compression improves considerably when you add oil.
Valves Leaking -- Compression is low on the first stroke. Compression usually does not build up on the following strokes. Compression does not improve much when you add oil.
If 2 adjacent cylinders have lower than normal compression, and injecting oil into the cylinders does not increase the compression, the cause may be a head gasket leaking between the cylinders.
Old Jan 6, 2008 | 05:16 PM
Robert@Advanced Dyno's Avatar
from my experience if you are checking your ls1 compression I see between 150-180 psi. On ls2 motors usually 170-200
I normally get concerned with a difference of 20% between cylinders
Good luck
Robert
Old Sep 10, 2008 | 01:29 AM
ferrari red vette's Avatar
ferrari red vette
is this what all corvettes should be reading? or just the above mentioned 2000 vette?
i have an automatic, 98...57k on the clock. thanks!
To Proper Compression?
