C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Recieved error code need help
Old Dec 31, 2007 | 07:51 PM
circusvargas1's Avatar
circusvargas1
Default Recieved error code need help
Hello
I recieved an error code and it is PO440 evaportive and emission system.(EVAP)
What does it mean?
Thanks all
Old Jan 1, 2008 | 12:03 AM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
If it happened just once probably just that the gas cap was not tight--The tank is sealed and bulids up pressure then purges it into the intake every so often to be burned--If not the cap--look for some gas leaks on the flooer from a cracked or broken vent line
