C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
PCM's
Old Feb 1, 2008 | 09:30 AM
WKMCD's Avatar
WKMCD
Default PCM's
I'm going to upgrade the PCM (re-pin the damn harness) in my 98. Which year should I use that will give me the best tuning capabilities?
Never mind. It looks like 01-02.
Old Feb 1, 2008 | 01:36 PM
doc@EFIAlchemy.com's Avatar
doc@EFIAlchemy.com
Cruising
Any 99-02 GM V-8 (512 kb) pcm will do. There were multiple hardware numbers over the years. The quick reference check is on the connectors it will read "Blue" and "Red." If you see any other color combo it is not the right pcm. Hint, avoid the vette / performance tax by looking for a lowly truck pcm. Same hardware, most recyclers don't know the difference though.
Old Feb 1, 2008 | 01:42 PM
WKMCD's Avatar
WKMCD
Great tip Doc. Thanks,
Kevin
Old Feb 10, 2008 | 10:27 AM
edcmat-l1's Avatar
edcmat-l1
I would stick with the 01/02 as they have a better VE table, and no secondary VE.
Just my .02, and thats probably all its worth.
Old Feb 10, 2008 | 12:27 PM
euro@EFIAlchemy.com's Avatar
0euro@EFIAlchemy.com
Former Vendor
The 99-02 PCM hardware is the same, We can program any Operating System we choose into it, the model year of the vehicle that the PCM came out of is irrelevant as long as it is a 99/02 Red and Blue PCM.
Old Feb 10, 2008 | 12:46 PM
JUSTIFIED C5's Avatar
JUSTIFIED C5
A plug and play harness would be cool, be able to plug into factory harness on one end and then plug in new style ecm, has this ever been done? Do they exist?
Old Feb 10, 2008 | 12:59 PM
Former Vendor
Unfotunetaly they do not exist, we actually made one but the problem lies in the male connector that is part of the PCM, Delphi does not make them anymore so to get them the cost would be outrageous.
Old Feb 10, 2008 | 01:31 PM
JUSTIFIED C5
I see, that we be expensive. My friend swapped his pcm on 98 to new style, quite a long process re-pinning all wires. I would like to do mine so we can put the roadrunner on it.
Old Feb 10, 2008 | 07:13 PM
edcmat-l1's Avatar
edcmat-l1
You are correct. Didnt think about it when I posted.
To PCM's
