C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
changing gears
Old Apr 7, 2008 | 01:53 AM
tmcclaff's Avatar
tmcclaff
St. Jude Donor '04 & '05
Default changing gears
Hi
I am changing the rear end of my 04 from 2.73 to 3.42s. Do I need a tune or will the on board computer recognise the new rear end gears
Old Apr 7, 2008 | 01:48 PM
cmb396's Avatar
cmb396
CI 7-8-9-10 Veteran
You will need to adjust your shift points. I believe your speedo will be fine, not 100% sure on A4's though.
Old Apr 11, 2008 | 08:25 AM
kww's Avatar
kww
I didn't need to retune when ECS but in my 4:10's (M6)
Old Apr 11, 2008 | 10:28 AM
euro@EFIAlchemy.com's Avatar
0euro@EFIAlchemy.com
Former Vendor
Since you have 2.73's, im assuming you are an A4, with the A4 you do need to have the tune adjusted for the gear's, it will change your speedo and shift points.
M6 no need whatsoever
Old Apr 11, 2008 | 02:43 PM
Mike Mercury's Avatar
Mike Mercury
there is no speedo error when changing rear axle ratios on any & all C5's.
as someone in the business; I'm surprised you didn't know that
Old Apr 11, 2008 | 04:18 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
Correct MN6 will not need any change going from 3.42 to 4.10s, however an A4 going from 2.73s to 3.42 will need the shift points changed.
Old Apr 11, 2008 | 10:09 PM
Former Vendor
well, i apologize for getting crossed up, as someone in the business we tune alot more cars then just C5's
As stated above in my first post and by wicked weasel, your tune will need to be adjusted with an A4
Old Apr 11, 2008 | 10:46 PM
slowtealz28's Avatar
slowtealz28
EFI, still looking for a price on the 2nd and 3rd gen SSAC headers, please pm me if you can.
Old Apr 11, 2008 | 11:13 PM
Former Vendor
Pm sent
Old Apr 22, 2008 | 06:09 PM
Ralphyboy's Avatar
Ralphyboy
St. Jude Donor '08-'09
I had 3.42's installed in my 03 A4. A good tune is essential to have your car run right. Shift points need to be changed, and alot of other things need to be adjusted. You will not believe it's the same car if all this is done correctly, but it must be done. Also, go to someone who is very familiar with A4 trans, because it is ALOT different from tuning an M6 from my experience.
Old Apr 22, 2008 | 09:16 PM
2079's Avatar
2079
Yes as stated you will need a tune and you will see a great improvement..BUT!! since you are in there you should put at least a 2800 TC then you will see a ..outstanding difference and it will perform like stock nice and tight." PS Ihave a 3200 "
Old Apr 23, 2008 | 07:01 AM
Wicked Weasel
Lets get everyone on the same page before people think a full tune is needed for a gear change.
First - if you have a MN6 and you are changing gears than nothing has to be done.
Second - if you are changing the gears on an A4 than the Shift points only need to be adjusted a tune is not needed.
For the most that is all that is needed. Once in awhile there is a problem with rev limiter on the manuals that recently has come to my attention which woluld need to be adjusted. It is very rare though and I only read about 3-4 cars that had this problem.
That being said if you want the most out of your A4 than a full tune (not just a shift point change) is needed.
Most people I talk to with MN6 just have the gears changed and they are happy. Most people I talk to with A4s get the gears changed and also opt to pay for a full tune to get more out of their car.
The choice is yours...
Old Apr 30, 2008 | 02:02 AM
tmcclaff's Avatar
tmcclaff
Hi all and thanks for the replies. I just ordered a predator so I can play around with the shift points. And yes I have an A4 the rear end will be changed some time next week so any suggestions to exact shift point changes
Tom
Old Apr 30, 2008 | 02:30 AM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
adjust shifts point by - 25.27 %
(tcc apply/release points too)
To changing gears
