C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Relocate MAF sensor
Old Apr 13, 2008 | 09:38 AM
Pro Street's Avatar
Pro Street
Default Relocate MAF sensor
Has anyone relocated there MAF sensor next to there TB.
If you have could you send me some pictures? I think my MAF has gone bad and my move it if I have to replace it.
Old Apr 13, 2008 | 10:28 AM
gojo's Avatar
gojo
http://forums.corvetteforum.com/show....php?t=1705010
Mine is a 100mm for an LS7 swap. Your MAF will be closer to the radiator. The LS7 TB is 2" farther back.
Maybe someone has a standard MAF moved.
I would encourage you to do it. You will be getting it away from the turbulance where the air from the Vararam converge. I found no issues with heat, at all.
Old Apr 13, 2008 | 01:29 PM
Pro Street's Avatar
Pro Street
Thanks for the reply!
Nice swap!!!
Old Apr 14, 2008 | 06:02 PM
Mrdrnac's Avatar
Mrdrnac
I was adding a CAI and filter to my C5 and relocated the MAF next to the throttle body at the same time, So far it works great. Here is a link to the the thread I posted showing how I did it.
http://forums.corvetteforum.com/show....php?t=1992727
Hope this is helpful.
Old Apr 14, 2008 | 06:13 PM
Pro Street's Avatar
Pro Street
Where did you get the rubber coupler for the TB to MAF sensor and do you have the size you used?
Old Apr 14, 2008 | 06:44 PM
gojo's Avatar
gojo
http://www.verociousmotorsports.com/
When you know your size, this place has a large selection under silcone hoses.
Old Apr 14, 2008 | 08:34 PM
LinearX's Avatar
LinearX
I, too, moved my stock MAF sensor back to the throttle body when I did heads/cam/intake. Aside from the MAF scaled being terribly out of whack from the rest of the mods, there have been no adverse effects of moving the MAF back.
Old Apr 15, 2008 | 03:41 PM
Mrdrnac's Avatar
Mrdrnac
For my 2002 C5 w/stock 85mm MAF I needed this size reducer:
3” long Silicone Reducer, 4.0" to 3.75" – Blue [SIL000542] that I got from http://www.siliconeintakes.com
Big selection of silicone hoses also, and good costs.
To Relocate MAF sensor
