C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
headers poor m.p.g.
Old Apr 27, 2008 | 07:57 AM
Bob's 01slpss's Avatar
Bob's 01slpss
Default headers poor m.p.g.
mileage went from mid 20,s to teens. just put on 1 3/4" ss headers and cold air intake. No cats air pump code comes on at times. will a tune help and what do i ask for in tune up. mail order tune up . Bob
Old Apr 27, 2008 | 07:59 AM
Bob's 01slpss
i forgot 2002 zo6
Old Apr 27, 2008 | 03:06 PM
slowtealz28's Avatar
slowtealz28
Yes a tune will definitely help. I would not drive a car w/headers and no tune... get one ASAP.
Old Apr 28, 2008 | 01:18 AM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Headers typically richen up the WOT fuel ratio--And in closed loop the computer is constantly adjusting the LTFT's--- What you need done can't be done properly with a mail-order tune--because you have to log the Part Throttle LTFT's and make adjustments--Then adjust the PE or WOT fuel ratio with a wide band 02 sensor---
Old Apr 29, 2008 | 12:15 AM
1slowFRC's Avatar
1slowFRC
I had a buddy have the same problem and a tune helped alot
Old Apr 29, 2008 | 02:06 PM
jedblanks's Avatar
jedblanks
All of the Above + change your o2 sensors after the tune. headers are usually the last straw that push them over the edge. Bad o2 = Bad MPG.
Old Apr 29, 2008 | 03:51 PM
4SFED Z's Avatar
4SFED Z
I had 11 mpg until I had one of the O2 sensors replaced and got a tune
To headers poor m.p.g.
By Michael S. Palmer | 2026-06-03 11:00:24
