The shft light can be changed using LS1 Edit but it is still not good for racing. There seems to be a lag in the shift indicator on the vettes as experienced on my Dyno run. I just installed a raptor today and it was easy to do!
also read the last post i followed i followed his instructions and tapped the pink wire for power! This is nice because the lgith is reset everytime you cycle the iginition so if you decide to change the setting you never have to disconnect the battery if you use a constant power source!
I know that they are set to turn on at 5,750rpm. If they are lagging consistently, then it could still be used. I don’t like to go past 6,000rpm, so if it consistently comes on at, let’s say 5,900rpm, and then would work for me. The question is are they consistently lagging the same amount all the time?
