C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Active handling warning light
Old Jun 27, 2008 | 07:37 PM
terry38's Avatar
terry38
Cruising
Default Active handling warning light
Hello,
My service engine soon light which then displays active handling keeps appearing. What could be the cause of this and is it something I need to take in to get fixed. Seems when I hit bunps at certain times my brakes kick in and the warning light goes on. I can restart the car and it will stay off for a while. Any ideas thanks.
Old Jul 5, 2008 | 11:34 AM
EHS's Avatar
EHS
You should check the codes.
Depending on the age and mileage of your car, it could be the harness to the front wheel sensors, or a bad ground.
Post the codes.
I was having similar symptons and just had my harness replaced by Corvettes-of-Westchester.
No more issues now.
Old Jul 6, 2008 | 08:43 PM
terry38's Avatar
terry38
Cruising
Thanks, I'll get the codes and post them.
Old Jul 7, 2008 | 05:30 PM
Calibur45's Avatar
Calibur45
I'm having the same issue...mine hasn't actually applied brakes yet tho thank God.
The code is C1288
Any help is appreciated
Old Jul 25, 2008 | 01:01 AM
terry38's Avatar
terry38
Cruising
My car has no code to post. The service engine soon then followed by service active handling appears. I checked for codes but it doesnt find any.
Old Jul 25, 2008 | 04:39 AM
EHS's Avatar
EHS
Scientifically impossible with a check engine light on.
Old Jul 25, 2008 | 06:22 AM
trussme's Avatar
trussme
The code is C1288
DTC C1288 is a Steering Sensor Circuit Malfunction...Type (this code #) into the C5 "Search" window & you will find posts relative to how-to service this problem.
Old Jul 25, 2008 | 06:26 AM
trussme's Avatar
trussme
Default here's how you need to check for codes...
FIRST YOU MUST
...(with the key in the on position, but the engine not running)
push and release the reset button until all messages are cleared...
next push and HOLD button #4
next push and release button #1 four times while holding button #4
When first engaged the on-board diagnostics go into an "automatic" mode which shows all parameters: PCM-TCS-RTD-BCM-IPC-radio-HVAC-LDCM-RDCM-SCM-RFA. If there are no problems, you will see "no more codes" on the ICP display. The computer will show two kinds of codes, "current" and "history," designated "C" or "H". A current code indicates a malfunction is present in the system whose module is displaying data. A history code indicates a past problem. When the screen displays "manual diagnostics," select the desired module by pressing the "options" button to go forward or the "trip" button to go back. Press "gages" to go forward or "fuel" to go back. To exit the diagnostic mode at any time, press "E/M".
If you want to erase or "clear" codes, press "reset."
Old Jul 26, 2008 | 06:08 AM
terry38's Avatar
terry38
Cruising
Hello,
The dealer wants $425 to replace the sensor in the steering wheel vicinty. The service active handling doesn't come on all the time, mostly when the air conditrioner is on.
Should I get this fixed or wait until it goes for good?
Terry
Old Jul 26, 2008 | 06:28 AM
EHS's Avatar
EHS
That price sounds about right.
You decide if you can wait if you're hitting bumps and the brakes come on.
Old Jul 26, 2008 | 08:38 AM
trussme's Avatar
trussme
Default ??
Terry...the way you describe (what causes your problem) sounds more like a connectivity or continuity issue rather than a bad sensor. Have you, or your technician, checked the wiring, grounds and/or connections that can affect this? it may just be a poor ground or a corrosive/dirty connection ..
Old Jul 26, 2008 | 09:29 AM
EHS's Avatar
EHS
See post #2 above.
Old Jul 26, 2008 | 12:49 PM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Default Looks like steering sensor....
Hello,
Looks like the steering sensor, but BEWARE...
Have someone who really knows the car check it out cause MOST guys that just replace the sensor DON'T FIX THE PROBLEM.
Chuck CoW
Old Jul 26, 2008 | 02:33 PM
RC45's Avatar
RC45
I solved my intermittent problems - turned out to be the interconnect plug from the ABS module to ABS pump.
The plug was partially dislodged, and displayed all of the above symptoms at various times, including slamming on the rogth or left front brake without warning at times.
Once the plug was firmly seated, all issues went away.
Its worth a look see.
Old Jul 27, 2008 | 08:23 AM
terry38's Avatar
terry38
Cruising
Thanks EHS,
I will look at the harness and connections first.
I don't like it when the dealer says it can't guarantee the fix, that is crazy.
Here are the dianostic codes from my car
c1287h
c1288h
u1160h
b2262h
b2264h
what does this mean in english?
Old Jul 27, 2008 | 11:43 AM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
Default Terry...Call me monday.....
Thanks EHS,
c1287h
c1288h
u1160h
b2262h
b2264h
Terry, Call me monday with the codes when I'm in the office....
I'll try to help you....914-332-0049
Chuck CoW
Old Jul 27, 2008 | 12:10 PM
EHS's Avatar
EHS
Thanks EHS,
c1287h
c1288h
u1160h
b2262h
b2264h
Terry -- Here is a link to the list of codes:
https://www.corvetteforum.com/techti...D=26&TopicID=1
Rather than us continuing to speculate, call Chuck of Corvettes-of-Westchester on Monday as he suggested above. He's one of the best Corvette shops in the country, and I'm sure he will be able to help you out.
Report back.
Old Aug 4, 2008 | 08:08 PM
terry38's Avatar
terry38
Cruising
Now all of my systems come on to service when I start my car. I can turn the car off and then restart it and they go off?
Any ideas?
Old Aug 5, 2008 | 07:51 AM
EHS's Avatar
EHS
Any ideas?
1. Have you called Chuck and spoken with him, as he offered above? What did he suggest?
2. What work have you done on the car since your other posts?
Let us know, and we can take it from there.
To Active handling warning light
