C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Timing Question
Old Jul 14, 2008 | 11:55 PM
Artic's Avatar
Artic
Default Timing Question
If I have 33 degrees of advanced timing and 1 degree retarded timing as a safety margin, What would be the consequences? Will my engine go Kabom?
Old Jul 15, 2008 | 08:26 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Depends on where you have the 33*---The timing at part throttle goes above 33 at many points--However if you are speaking about WOT-I would say that that is really pushing a gen3 motor--also if your knock sensors are working you probably will never get an actual 33* even though you are commanding it--The KR system should automatically remove timing if it senses any pinging if they are working properly--but why chance it---My experience with timing on these motors is that adding timing does not result in huge HP gains as thay might on a SBC or BBC--I've experimented with 19* all the way up to 30* and have settled on 24 with ls6 heads at 10.49 compression-I did lose 8HP at 19* but the comp took out timing with 30 down to 27-----24 seemed to be a safe compromise with 91 octane Calif gas and I did not see more than 2-5 HP difference at ay setting on the dyno other than the 19 whee i lost 8----Again I am talking about pump gas--Working with 100-110 oct race fuel could net you some different results but I would be willing to bet that the gains would be minimal--
Old Jul 16, 2008 | 10:52 PM
Artic's Avatar
Artic
Thanks for your response. My is set to 30 now, and 28 if it knocks at WOT. This is now a 383 stroker, ls6 block. I had another tuner tell me to set it at 28. His explanation was the automatic transmission will last longer.
Old Jul 17, 2008 | 09:46 AM
Slow Z06's Avatar
Slow Z06
So you are saying you are at 30 across the board??
Old Jul 20, 2008 | 07:04 PM
muncie21's Avatar
muncie21
If you are going to set your max advance at 30*, I would set your available retard at 10-12*. This way you can use all the timing you want until it starts to ping. The PCM will pull timing (up to the max retard) incrementally until the pinging stops.
To Timing Question
