OBD-II Communications Protocol
I did this on my 1994 Z28 although that simply used a protocol similar to RS-232.
My preliminary research shows there are several variants on the OBD-II protocol. I'm not sure which one to research further as I don't know which one is for the corvette.
Does anybody know what the protocol is?
Where I could find additional information on the PCM?
Are there any forums devoted to this stuff etc.?
My goal is to create a cheap and simple adapter we could all use to interface with the PCM. It'll probably make use of a little microcontroller and would only cost a few dollars to build. The hard part is learning the protocol.
Thanks!
Let me know when you get your prototype going!
" The MC33390 is a serial link bus transceiver designed to provide bi-directional half-duplex communication meeting the automotive SAE Standard J-1850 Class B Data Communication Network Interface specification. It can be used at speeds up to 20 kb/s in non-standard applications.It is designed to interface directly to on-board vehicle microcontrollers and serves to transmit and receive data on a single wire bus at data rates of 10.4 kb/s using variable pulse width modulation. The MC33390 operates directly from a vehicles 12 V battery system and functions in a "true logic" fashion as an I/O interface shifting the micro- controllers 5.0 V CMOS logic level signals to 0 to 7.0 V waveshaped signal swings required of the bus. The bus output driver is short circuit current limited. A tristateable 4X/loop mode select pin is used to invoke normal wave shaped J-1850 Class B operation (0 V), disabled waveshaping high speed operation (5.0 V),or looped-back transmitted Tx output to Rx signal after having been wave shaped but not transmitted onto the bus (high impedance). The loop-back mode is used to confirm operational integrity independent of the bus. Though the MC33390 was designed for automotive SAE J-1850 Class B Standards, it is suited for other serial module-to-module communication applications.s was principally designed for automotive applications requiring SAE J–1850 Class B standards, it is suited for other serial communication applications.. It is parametrically specified over an ambient temperature range of – 40°C 3 T A 3 125°C and 7.0 V 3 V Bat 3 16 V supply. The economical 8–pin SO–8 surface mount plastic package makes the device a cost effective solution.he device a cost effective solution.. "
http://sites.google.com/site/ehudv2/
It will work in any 1996-2003 Vette.
Here's what I'm working on for V1-HUD interfacing into the C5 and C6 (with additional complete OBD-II functionality for up to the 2003 model year).
http://sites.google.com/site/c6v1hud/
