Running like crap!!!!!
P0101 is "MAF sensor performance" The bucking you're feeling is caused by the MAF-especially on an automatic it is more noticable--Can you check the LTFT's somehow ?? Also--have you recently cleaned or re-oiled the air filter ? Over oiling will cause poor MAF performance--Clean the MAF interal wires with some TB cleaner or Brake clean--Did you remove the screen ? a NO NO---You may have a vacuum leak causing unmetered airflow --or it may be a Plugged PCV system
P1133 is "insufficient switching of the FRONT /DRIVER'S side 02 sensor"--generally caused by the 02 not heating up --Do you have headers or recently made an exhaust change ?? It usually is an exhaust leak-- or can be a bad sensor--
The 2 codes CAN be related--but not neccesarily--the 02 sensor may be sending false data back to the computer because of an exhaust leak-If the error is over 25% then the computer will NOT be able to compensate enough to achieve the 14.68 AFR in closed loop--throwing the MAF code--
The fact that it runs fine at WOT shows that the problem concerns closed loop operation and at WOT it is in Open Loop/PE and the 02's aren't being used--
