Tuning question
Stephen
(Which seems to be the original complaint).
The last conversation we had he decided to take matters into his own hands and said he was going to supply his own parts and just wanted us to do the labor and tune the vehicle when it was done. This is something I will not guarantee anything on as far as horsepower numbers. I was hesitant because he told me he had found a used Magnacharger kit but since I had already spent this much time with this guy I went ahead and agreed to take on the job. This is where it gets interesting. A few weeks go by and he shows up one day and drops off about ten different boxes of different sizes and colors. Magnacharger kit, camshaft, cylinder heads, pushrods, valvesprings, lifters, oil pump, clutch, headers with H-pipe, boost and fuel gauges, and a Gen 1 small block chevy chrome thermostat housing. EVERYTHING I just listed was USED, purchased off of eBay and other related sources and some of it wasntt even correct for this application. To make this long story a little bit shorter, the non-intercooled magnacharger kit was NOT complete, the cylinder heads as Roy stated were poorly ported if any at all and looked fairly stock otherwise. The camshaft was not of the specs that I had put on the package I quoted him. I did not know what to say about someone actually purchasing a used clutch and willing to pay the labor that it consists of for installing it especially in a C5. We let him know we were hesitant about putting it in but he insisted because the guy he bought it from on the internet said it had "low" miles on it.Ok, we went ahead and got started with this project because he had some "Corvette shows" that he was wanting to take it to. Throughout the process, he would stop by and grab parts that were removed to take to either get plated, painted, polished or what have you. Everytime he did this it would halt progress of the project because we wouldnt see those pieces back for days..sometimes a week. He didnt feel he attributed to the time it was taking to complete the project yet we have a car stuck on a lift up in the air because of this. Weeks went by, we finished the car, started it up and it had an oil leak due to the aftermarket chrome front timing cover. We went ahead and repaired it for him at a discounted rate just to get the job done and he agreed. He then came to the shop to pick it up two days after we told him it was ready and went to test drive it and came back with an idling problem. We went outside to try to duplicate it and it wouldnt. So we figured maybe its a cold start issue so just leave the car another day so we can sort out the issue and see if it will happen again in the morning. We did NOT tell him we were only going to "raise the idle". Ofcourse that is not going to fix the problem as it idled just fine when he came back from the test drive at normal operating temperature. The next day we duplicated the problem and addressed it as needed, started the car up at various times of the day, drove it, and decided to keep it another day just to make sure it wouldnt do it again in the morning. All was good the next day so we called him to come and get it. He shows up, goes for a test drive for about 30 minutes, comes back and said "its fixed. It runs and idles great. Can you put some air in my tires they are a little low and i want to go drive it some more". Sure no problem. He's off again. About 3 hours go by and we are wondering where he went and if everything is ok. (Mind you he hadnt paid a penny of the remaining balance of this project). About 7:30 pm he shows up to pick up the original car he drove up here and starts talking to my employees downstairs for about a half hour about how well the car ran and got sideways on him when he floored it. He then comes upstairs while Im doing some paperwork and has a copy of the invoice in his hand which he modified in his own way on how much and what he was going to pay for. He subtracted the Dynotune, installation of the gauges and pillar molding, and the repair of the leaking front timing cover seal. I asked why do you feel you don't have to pay for he dyno tune when you just drove the car twice, and told us that everything is fine? His reply was "well this is my first go-around with something like this and I need to go have another shop check it out to make sure its ok before I pay you for it. Also, I dont see how you guys could have tuned my car with the tire pressure being that low (25psi)". Ok, I dont agree but why are you not going to pay for the installation of the gauges? "Well I originally wanted them on the side of the center console". -He brought us a dual gauge pillar molding and gauges to install. We started installing this then just before they were wired up he called my employee and told him to stop, he didnt want them there. Employee told him that they were pretty much installed and holes had already been drilled to secure the pillar molding. At a later date, the owner of the car told him to go ahead and finish installing the gauges in the original location. About the front seal leak. He claimed we should have known that the leak would have happened due to the used ebay crank pulley and aftermarket chrome cover/seal.
We tried to explain to him the best way we could that we performed the services that he requested and agreed on and he agreed that everything was ok at time of delivery. He still refuses not to pay the balance in full and leaves partial payment and walks away. Being the fact that he is a Fort Bend County Deputy I had second thoughts about what to do. Hold his car here? Wait, cant do that because he took it home on the test drive and locked it up intentionally. Physically detain him? Call the police? Wait, he is the police!? I was thinking maybe since he is a deputy and we were aware of that, he could use that power against us and pay what he just simply felt like paying. So, I discussed it with my employees and decided to call him to discuss this futher and resolve it. No answer from my phone after numerous calls. The next day we call from an anonymous number and he answers and says he will come by shortly. The day goes by with no answer to our calls. So I decide to go ahead and call the police and they come by and confirm that he performed "Theft of Services". Since one of the deputies that responded to the call recognized his name and that he went through the Police Academy with him asked If he could try to resolve it with him before I file charges. I agreed. Im not out to try to slander someones reputation but I refuse to be ripped off so I will give it until 2pm the next day. I understand that the Lieutenant of the department was informed of this and he came by and paid the balance in full the next day.
Let it be known that the whole invoice at the beginning of this ordeal was discounted just because he was a deputy of the area where we are located. You live and learn, and good luck to whoever takes on this project in the future.
Mike@ICON Autosports
Cheers,
Frank
We had a deputy drive his car into the ditch in front of my inlaws land near Tomball. I could smell the alcohol from 10 feet away. He finally managed while stumbling drunk to get it out 5 mins before the cops showed up. As far as I know he got home that night with his job intact.
very interesting to read all those posts actually.
carbonfibervette: off topic, but as a regular seller/buyer on Ebay, I have found to NEVER, EVER buy anything but completely brand new, out-of-the-box parts, or anything for that matter.
I'm not saying that was the problem in this circumstance, but just my piece of advice
Part of running a profitable business is recognizing those you cannot afford to have as customers.
. I'm glad that both sides were heard and it sounds like Mr.Cop was BSing all of us..
