C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Does gearing affect AFRs?
Old Dec 12, 2008 | 02:33 PM
FourG63 97GST's Avatar
FourG63 97GST
Default Does gearing affect AFRs?
Basically I'm trying to find if tuning in 3rd gear compared to 4th affect A/FRs? since I street/track tune an only get full 1st tru 3rd gear passes.
so how does the load difference affect AFRs?
Old Dec 17, 2008 | 02:47 PM
Tuner@Straightline's Avatar
Tuner@Straightline
The load in third gear should be close enough to fourth gear, that you'd be good. The reason we do dyno pulls in 4th (manual, 3rd auto) is because that is the gear that gives the drivetrain a 1:1 ratio for more accurate dyno numbers.
First and Second tend to be a little leaner do the lighter engine load. It's pretty cool seeing the the AFR plotted on a graph over time like we can do with our Mustang Dyno's 1/4 Simulation. Where we might be at 13.0:1 AFR in fourth during our HP Tests, we could be 13.2:1 in the lower gears during a 1/4 Simulation.
Old Dec 17, 2008 | 03:38 PM
FourG63 97GST
thanks alot. with that being the case, I should be little in 4th anyway
To Does gearing affect AFRs?
