C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Need help with codes please.
Old Jun 20, 2009 | 12:22 PM
Daleford's Avatar
Daleford
Default Need help with codes please.
My 01 coupe service engine light came on 2 weeks ago. As I was rusty with reading codes, and there seemed to be a lot of older [H] codes, I cleaned all codes away. Servive engine light went out but came back after 100 miles. Here is what I now read:
10-PCM, 2 codes, P0410 H C and 1431 H
BO-RFA, 2 codes, U1000 H and U1064 H
Thanks for the help
Old Jun 20, 2009 | 01:02 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Hi--the P0410 is for the secondary air injection system--It does not specify which bank (left or right) so it is most likely something that affects both sides--make sure the air inlet hose is connected-and try to diagnose it from there
P1431 is a fuel level sensor code---Does your fuel gauge work correctly ?It could be a false code--see if it comes back
Both the U codes (U1000-U1064) have to do with loss of communication to the ECM---These codes are quite common--U1000 is a not communicating with the serial data & U1064 is the loss of that data---These are often set when the battery is disconnected or very low voltage---ALSO often aftermarket equip. such as stereos-amps etc will trip these type codes--Ultimately a true code of this nature could signify a bad ignition switch or shorted wiring---Most likely they are false codes and not an issue--just annoying---However if you begin to notice other things popping up that may be related to the key or switch then i would look further into it---
Old Jun 20, 2009 | 03:37 PM
Daleford's Avatar
Daleford
OK Thanks for the info. I'll work on this.
I understood that a code followed by an H is a history code and not a current problem. I was told a code followed by a C is an existing [current] problem. Am I wrong on this?
Old Jun 21, 2009 | 02:53 AM
MYLS6's Avatar
MYLS6
no you are correct.. try these link to help...
http://www.stengel.net/diccodes.htm
Old Jun 21, 2009 | 09:04 AM
edcmat-l1's Avatar
edcmat-l1
For more info on your codes, check out www.gearchatter.com.
Old Jun 21, 2009 | 10:48 AM
Daleford's Avatar
Daleford
Good info guys thanks. I printed it off.
So back to my first post. Since the H codes are history, the only code I need worry about is the 10PCM- P0410HC correct?
That code rings a bell. Last year it came on and I posted here: http://forums.corvetteforum.com/c5-t...scan-help.html
I ended up installing a new "in the box air pump" and the problem was solved for quite a while.
It is odd that it has returned, but we will look closer into this.
Last question. Why is it that if I delete old codes followed by an H, they return?? As I said, after I deleted all codes a week ago, I had a clean slate. If the only current problem is the 10PCM - P0410, why do the old H codes return??
To Need help with codes please.
