called alkycontrol today and was told they use a stardard 2 bar gm map sensor and the green wire could be tapped for logging boost
Just curious, I am not FI yet, but I have installed sensors for logging EFI Live such as Nitrous Bottle pressure and fuel pressure.
Correct me if I am wrong...If the two bar sensor replaces the stock sensor, you should be able to log using the MAP PID without connecting the wires...EFI Live will read the MAP voltage from the PCM.
I think you need to custom program the MAP PID to recognize it as 2 Bar to report correctly during logging?
