C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Diablo predator
Old Jul 24, 2009 | 01:31 PM
LS9Drew's Avatar
LS9Drew
Default Diablo predator
hows every1 like theres? on a z06?
Old Jul 26, 2009 | 10:50 AM
NOT2MELO's Avatar
NOT2MELO
Had one before for the vette and CTS-V, great for killing CAGS, adjusting the fans, and quick tune of your fuel
trims for hwy economy. The performance tune is not bad but nothing like a real road/dyno tune.
Old Jul 26, 2009 | 12:34 PM
LS9Drew's Avatar
LS9Drew
ya thats wat i didnt wanna hear lol. dyno tunes are so much $500
Old Jul 26, 2009 | 12:57 PM
06MonteSS's Avatar
06MonteSS
Supporting Vendor
you gain about 20-25 hp/tq... the tunes remove the torque management, increase timing, adjust the PE/WOT fueling, etc etc..
you can gain even more over the preset canned diablo tunes by getting a custom predator tune made for your vehicle via email...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS LS3, short-throw shifter, NPP perf. exhaust, BMR strut-tower brace, Cold Air Inductions cold air intake, catch-can, ported/polished TB, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old Jul 26, 2009 | 10:35 PM
LS9Drew's Avatar
LS9Drew
o so i just send a datalog? cuz the thing is basically stock just air filter and throttle body by pass
Old Jul 27, 2009 | 03:01 PM
06MonteSS's Avatar
06MonteSS
Supporting Vendor
yeah, once you have one, you would install the diablo tune, put on some miles, then just do some data logs, logging specific parameters... and then you'd send the logs and copies of your tune files to a tuner and pay 'em to make you a custom tune for your car...
they would make you a custom tune file with all their tweaks/adjustments, and then email you that new custom tune file... then you import it to your predator, and then install it to your car...
piece-a-cake...
Old Jul 27, 2009 | 03:40 PM
Brian@RPT's Avatar
0Brian@RPT
Former Vendor
I have tuned many cars and the street tune works great. The important thing is use a wideband before adjusting any of the WOT parameters. On my Vette, I gained 20 rwhp and the throttle response is greatly improved. Where are you located?
Old Jul 27, 2009 | 06:24 PM
LS9Drew's Avatar
LS9Drew
nor cal. was deciding between the diablo or trifecta as thats wat i have for my cobalt
Old Aug 1, 2009 | 11:43 PM
baddboyz03's Avatar
baddboyz03
Old Aug 9, 2009 | 02:28 PM
Bop Bop's Avatar
Bop Bop
A local shop charges $100 an hour to use there dyno. I used my predator to tune with. I got an additional 11 RWHP over what I already had. Cost me $100. The real reason I went in the first place was to check the timing on a 100 wet shot. The 11 additional rwhp was just a bonus.
Old Aug 29, 2009 | 02:06 PM
LS9Drew's Avatar
LS9Drew
ok so should i go with diablo or trifecta? and on the diablo do i have to adjust the timing and everything myself or does it come with all that stuff done?
both are under 350
Old Aug 29, 2009 | 03:18 PM
06MonteSS's Avatar
06MonteSS
Supporting Vendor
timing and everything is already adjusted in their Diablo Tunes on the predator...
you can just install it and go...
but you'll be able to gain some more if you do data logs and get your fueling dialed in more, etc etc...
Old Aug 29, 2009 | 03:20 PM
LS9Drew's Avatar
LS9Drew
do i send them back the datalogs? and they adjust it or do i get some1 else to adjust it?
do z06's come running rich from the factory? it would be nice to pick up a few more mpg
Old Aug 29, 2009 | 04:23 PM
06MonteSS's Avatar
06MonteSS
Supporting Vendor
yes, it's rich from the factory, but the diablo tunes will lean it some for ya...
no, you do the datalogging and adjusting yourself... or pay to get a custom tune done... then you'd send the person doing the tuning your log files, and also copies of your original backup tune and a copy of the current diablo tune that you installed in your car... they will also tweak a bunch of other stuff besides just the fueling as well... I have done many of them...
info about logging and how to make the part-throttle fueling adjustment yourself can be found here:
http://diablosport.com/index.php?nam...iewtopic&t=917
To Diablo predator
