I have a GM 3 bar map sensor. The part number is 12223861. Ive searched and searched, cannot find my answer. Will this 3 bar map sensor work on my Vette? If so what harness adapter do I need or do I need to splice and dice? Thanks for any info!
I believe any GM map will work. Speed inc has the connector you need so does ebay. Im not 100% sure that map will work but pretty sure. I was told as long as its a gm part number.
This should help put your mind at ease. Also Phil Simms has the adapter harness you need along with some 60# injectors.
haha, I already talked to him and it will be a while before he sells the injectors, and I had already ordered the harness! Get ready for it, its coming to your house soon to tune it!!!
