C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Power Programmers & Performance Tuners?
Old Mar 12, 2010 | 02:56 AM
mel3535's Avatar
mel3535
Default Power Programmers & Performance Tuners?
What do you guys use if any at all? Are they any good? I was told i can gain up to 30RWHP, even though i don't believe this, i wanted to know what you guys think?
I was thinking about getting Hypertech Max Energy Programmer (http://www.autoanything.com/performa...0A2352636.aspx)
Old Mar 12, 2010 | 07:48 AM
dbaker's Avatar
dbaker
I didn't see any details about your car,but I can tell you my experience with a Diablosport Predator on my 02Z.The only perf mods on my car is a VRB2 and a Halltech honeycomb MAF screen.
I installed the performance tune( 93 octane tune) and tuned out CAGS,COT,adjusted timing,adjusted the fans and got my LTFT's in line.I would say,as an estimate that I got 10-15 more HP & TQ.
Bear in mind,that is just an estimate.The car is more driveable and I am very pleased,plus I like the fact that I make adjustments anytime or go back to the facto tune easily & quickly.
The Diablo folks have a good web site and good forum usage.
I don't have any experience with other hand-held tuners.Most of us know that a custom tune is best,but unless you drag/track your car,these hand-helds are plenty good enough,IMO.
\db2
Carolina
Old Mar 12, 2010 | 12:30 PM
Shirl's Avatar
Shirl
2025 C8 of the Year Finalist - Modified
2021 C7 of the Year Finalist - Unmodified
Yep, do a search.. I've posted several times that I've had excellent results with the Predator!
Old Mar 12, 2010 | 01:36 PM
06MonteSS's Avatar
06MonteSS
Supporting Vendor
Predator...
offers full data logging, trouble code scanning/clearing for ANY gm vehicle, better tunes, and has more adjustability options than the other one...
plus, the predator allows you to get and store up to 5 custom tunes in it, created specifically for your car by a diablosport CMR custom tuner (like myself), to get even more giddy-up out of your car...
with the predator, you're able to adjust:
Timing Table 1000-3800rpm (+15/- 20%)
Timing Table 4000-4800rpm (+15/- 20%)
Timing Table 5000-7000rpm (+15/- 20%)
Fuel Table 1000-3800rpm (+/- 20%)
Fuel Table 4000-4800rpm (+/- 20%)
Fuel Table 5000-7000rpm (+/- 20%)
Idle (+ 500rpm / -300rpm)
Speed Limiters (adjustable for Trucks Only - already disabled in the tunes for cars)
Rev Limiters
RPM Shift Points
MPH Up and Downshifts
Shift Timing
Shift Pressure
Cooling Fan ON and OFF temperatures
Re-Calibrate Speedometer for Gear and Tire Size Changes
Upshift torque reduction (all gears) ON/OFF
Adjust for different injector size
Adjust COT enable temperature
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS LS3, short-throw shifter, NPP perf. exhaust, BMR strut-tower brace, Cold Air Inductions cold air intake, catch-can, ported/polished TB, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
mel3535's Avatar
mel3535
I have a 04 Coupe, pretty stock right now but i will be putting a CAI pretty soon. I am thinking about getting the Hypertech Hyperpac because i can change my gear ratios with it and my friend who has a 98 BMW 740i claims that he got 50 more HP from it!!!
I i am pretty new with this kind of stuff here, how easy is are these things to use, can someone who has never used one just use it.From what i have heard Power Programmers just ask you questions and do everything for you, is that true?
To Power Programmers & Performance Tuners?
