Diablo Predator
if you don't do that, then the predator will still be locked to your car and no one else can use it.
so, if you restored the original backup to your car before you tuned it with hp tuners, then you are all set.
if you did not, then you have to use hp tuners to put back the "stock tune" to the car that it saved... then hook up the predator to the car and go to OPTIONS > TROUBLESHOOTING > RESTORE ORIGINAL BACKUP in order to do the restore process...
then your predator will be unlocked/reset and good to go for someone else..
and then finally, us hp tuners to put your custom hp tune back on your car.
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS LS3, short-throw shifter, NPP perf. exhaust, BMR strut-tower brace, Cold Air Inductions cold air intake, catch-can, ported/polished TB, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
