C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Knock ?!?
Old Apr 4, 2010 | 06:27 PM
Trueblood22's Avatar
Trueblood22
Default Knock ?!?
Is this legit detonation? I am seeing knock retard pretty regularly, and my idle will stick high and surge randomly. Any ideas on what's going on?
Old Apr 4, 2010 | 08:30 PM
frcslave's Avatar
frcslave
Need more information about your car - modifications, auto/manual, ect...
Can you hear any audible pinging? Attatch your tune file and a log as well so we can have a look.
Old Apr 4, 2010 | 09:46 PM
Trueblood22
It's a 99 c5, manual, axle back exhaust, underdrive pulley, vararam, 75 shot
There is no noise at all. Config and Log in links.
Thanks for the help!
http://www.mediafire.com/?lodny52o1xi
http://www.mediafire.com/?5n0zw2mgezt
Old Apr 5, 2010 | 07:57 AM
frcslave's Avatar
frcslave
Post up a file for your tune.
Looking through that log it seems like you may be a bit lean, but is there any reason you are going WOT for short bursts below or a little above 2000rpm? Is this the only time the KR is kicking in?
In the Knock Retard histogram you can hit the + button to see the maximum knock retard in each cell and then copy it and paste special - subtract it from your spark advance table or try increasing your PE values at those rpms.
Also, do you have the nitrous set-up on a window switch or is it only on a WOT switch?
The idle problem may be in the tune or due to a mechanical issue. Make sure you have no vacuum leaks or any unmetered air coming in after the MAF. If everything is sound mechanically then you may need to tweak a few idle airflow tables in the tune.
Old Apr 5, 2010 | 08:45 AM
Trueblood22
Car has the stock tune.
I am only seeing KR on WOT N/A runs in 3-4 gears. I lost the hard drive in the computer that those logs were on and was just trying to get KR to kick in logging last night (wet and rainy). I had just noticed from the one screenshot I still had from the old computer that when I was pulling a hill at cruise speeds it was also kicking in.
Nitrous is HSW microedge and interface. Windowed, A/F shutdowns 10-13, TPS.
I'll spray test for air leaks. Pretty good chance my nitrous plate isn't perfectly sealed.
Old Apr 22, 2010 | 02:16 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
97-99's are prone for false knock issues---In 00 GM changed the sensors to fix this-- false knock can occur with engine mods--especially exhaust changes as the sensors are picking up new noises
You may be a bit lean as mentioned at WOT---I would start there especially with NOS you don't want that--Try addding some fuel in PE and see if it goes away- If not you can desensitize the knock sensors slightly at WOT only-- In the SPRK table go to "knock software" and go to the "cylider mode " "B" try addding .10 in the last 2-3 columns
(WOT) only
As far as the surge at idle you basically have a stock type eng--there should be no reason for surging so it sounds like you have a vacuum leak as mentioned or un-metered air coming in--If you can't find anything more than likely its a result of the varraram intake--You may have to adjust the ""desired airflow" table to compensate by adding a % to both tables start with 10%--But 1st make sure your LTFT fuel trims are in line ---"0" or slightly negativein the idle ranges
Old Apr 22, 2010 | 07:23 PM
Steve@TunedbyFrost.com's Avatar
0Steve@TunedbyFrost.com
Former Vendor
Originally Posted by tblu92
--Try addding some fuel in PE and see if it goes away- If not you can ....
The car is not in PE in the screen shot; it's clearly in CL. If you look at the frame that precedes the knock, both narrowbands are in transition low. That is the trigger in that instance for a value that is a bit too high for current conditions.
Old Apr 22, 2010 | 11:29 PM
Trueblood22
Thanks for the input! I tightened up my nitrous plate and it definitely helped the idle surge, you hit that one on the head. My clutch is starting to slip at the top of 3rd and 4th, so I've been pretty easy on it lately. Plan on putting a new clutch in this weekend, and starting the tuning process soon. (I'll have plenty of non-WOT time to work on tables). I've switched over to 93 octane now and I'll go ahead and adjust the knock sensitivity and report back when the clutch is broken in.
I appreciate the help.
Old Apr 23, 2010 | 12:20 PM
tblu92's Avatar
tblu92
I wasn't going by the screren shot--its too hard to read--just by what he says " I am only seeing KR on WOT N/A runs in 3-4 gears. "
It may have some KR down there in CL but it seems he's more concerned about WOT according to his own words
To Knock ?!?
