3 Codes Keep getting Throw, Any Ideas?
P0327- Knock Sensor (KS) Circuit Front
PO332- Knock Sensor (KS) Circuit Rear
P1416 - AIR System Bank 2
Now the car won't take full acceleration, the engine will cut off at full throttle. But as soon as you let off full throttle it will accelerate slowly. Any ideas on what is causing those codes?
Most likey that is the cause for the "low frequency codes on your sensors-- A stuck AIR valve or AIR leak can make strange exhaust noises--which are being picked up by your sensors--
I would start there---then clear the codes also check ALL the AIR hoses---make sure the one that goes onto the air cleaner box is hooked up---Check the AIR fuses in the panel--and i think there may be an AIR relay as well--
The P14 code is a manfacturer specific emissions control code.
Go over the basics, like premium gas. There is a TSB for C5's that you must run top tier gas like Shell, Chevron, 76 etc. There is a whole list of gas stations that are accepted on that TSB. It could be something as simple as you going to a gas station consistently that has bad gas, that could cause it.
If all of that is ruled out, then insure that the spark plugs you got are obviously gapped correctly, or that they are manfacturer recommended.
start there, and then we can hopefully help in further diagnosis.
