C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
A4 tuning
Old Jul 29, 2010 | 03:22 PM
rclinton's Avatar
rclinton
Veteran: Marine Corps
Default A4 tuning
For those who tuned there A4's what speeds did you set for partial and WOT TP. upshift/downshift
Old Jul 29, 2010 | 04:47 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
That depends on owner preference. I start in part throttle tuning with an increase of 3 MPH under 50%, and add up 1 or 2 MPH from there. Dont forget adding the same amount up to your downshifts.
Dont forget to reduce your torque management
Old Jul 30, 2010 | 02:45 AM
rclinton's Avatar
rclinton
Thanks for the reply, I will have to get my stock tune from my tuner to compare.
Old Jul 30, 2010 | 07:56 AM
phils C5 vette
that's the hard part about the tranny tunes. I may like one shift range, another tuner likes a differant range, and the owner doesnt like either and may want it higher or lower/ softer or harder shifts.
The transmission tune is driver/owner objective.
I did an F body last week, and he liked everything about the tune, but after a couple days of driving, he wanted the shift points lowered
2 MPH in part throttle, so he came back that day and I lowered them. It took 10 minutes to change and scan, but its owner preference.
Call your tuner and communicate your feelings, and it doesnt take long to change.
Old Jul 30, 2010 | 12:57 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Depends on many factors---especially rear gear ratio---a ratio like a 2.73 will tend to short-shift and lug while driving around town---i like to tune A4's by letting the engine RPM's hover around 2000- 2200 RPM's when shifting under normal driving accelation --It prevents the engine from lugging which makes it a dog and is horrible for fuel milage
Sound like you are using a handheld tuner---A handheld does not address shifting tables prperly--at PT they don't adjsut the downshift points-- at WOT that's a whole new thing--The ECM must hit 2 parametrs in order to command a shift--1st it must hit the commanded MPH and then hit the commanded shift at RPM point-- a handheld does not address these properly either---only a full tuner like EFILIVE or HP does---there are so many things a real tune can do do make our car quicker without adding a single HP !!! i've seen gains of up to 1/2 second in the 1/4 mile--- The WOT downshift tables are huge as well
Old Jul 30, 2010 | 03:38 PM
rclinton's Avatar
rclinton
For the most part I'm loving the new found power of the V-2 and the tune. Just noticed that it seemed to short shift 1>2 on normal driving so when I got HP tuners I was looking at the tune and noticed that it was set to shift at 11 MPH at 6% TP graduating to 28 at 50% TP. Easy enough to change the numbers and see how I like it. Just wondering what others had found to their liking.
Old Jul 30, 2010 | 03:48 PM
rclinton's Avatar
rclinton
I am using HP Tuners pro (well actually I just got it so Im just really looking at things) On the Transmission >Auto Shift Speed >part throttle shift>Normal> and the table for upshift/downshift vs %TP. I dont see a RPM shift table for Part throttle. For WOT there are both Speed and RPM charts. Am I missing something? I am running an A4 with a 3.15 rear. Thanks though for giving me an RPM range to look at while testing.
Old Aug 1, 2010 | 12:04 PM
tblu92's Avatar
tblu92
There isn't a RPM table for P/T---The only way to get the shifting to hover around 2000 2200 RPM's is to make a change and drive it to see where the RPM's are at-----trial and error--
EFILIVE does have a calculated RPM for PT shifts that you can use as a reference or starting point--but the real only way to get it accurate is to drive it--
Old Aug 1, 2010 | 12:49 PM
rclinton's Avatar
rclinton
Thanks all for the responses. As I learn more about HP Tuners I'm sure things will become clearer. I want to especially thank Phil (Phils C5 Vette) for answering my questions and even took a look at my tune and offered up some changes. His time spent and information he gave me was invaluable. When I offered him some payment for his time he refused. Thanks Phil.
Old Aug 2, 2010 | 08:25 AM
phils C5 vette
You paid us plenty with your service to the country
Enjoy the changes
Old Aug 4, 2010 | 12:18 PM
Paul Kersey's Avatar
Paul Kersey
Dammit guys, you're giving me a warm and fuzzy.
Old Aug 4, 2010 | 02:27 PM
rclinton's Avatar
rclinton
Well "The Tuning School" home course has been delivered and waiting for me at home. I might start having more questions than ever!
To A4 tuning
