To turn off the codes correctly you have to 1st set the enabler to ' not reported" and 2nd set the MIL to "no mill"
You can turn off the AIR pump with a tuner but on mine the only way i could get the AIR pump NOT to come on inadvertantly was to unplg the pigtail on the pump ( under the drivers front headlight)
here is a link about that code too---- http://www.gearchatter.com/viewtopic...?view=previous
