C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
ECM help
Old Jan 17, 2011 | 10:24 AM
ssdungeon's Avatar
ssdungeon
Default ECM help
I cant check my HPT module until Thurs. Can anyone tell me which wire under the dash of a 97 C5 powers the programmer? I have checked ALL fuses. I have looked at the OBDII port and it all looks ok the pins appear to be there. I just want to check voltage because the module never lights up.
IT COULD just be my HPT but I dont have an OBDII vehichle for the moment.
Old Jan 17, 2011 | 12:43 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
The fuse to power up the OBDII port is hidden by GM --It is the cigarette lighter fuse---
Old Jan 17, 2011 | 01:25 PM
ssdungeon's Avatar
ssdungeon
Yip checked that. Its good.
Old Jan 20, 2011 | 08:52 AM
ssdungeon's Avatar
ssdungeon
The fuse is good and the outlet under the armrest works but the one under the radio does not. Should I try putting 12v to the one under the radio with a .5 amp fuse and see if it gives it power.
To ECM help
