C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
check engine light on
Old Feb 22, 2011 | 05:53 PM
veselik1's Avatar
veselik1
Default check engine light on
I have an 02 c5. I put in a k&n air filter and the check engine light came on, I have turned it off several times with an obd 11, but it is now time to go through the local DEQ and it will not pass with the light on, does anyone know how to turn it off permanently?.Thanks, mike
Old Feb 22, 2011 | 09:11 PM
06MonteSS's Avatar
06MonteSS
Supporting Vendor
need to get a tune and have your fueling adjusted correctly to get rid of the lean condition most likely being set by the CAI...
only way to do it...
you can keep clearing it, but it's going to keep coming back...
did you just put in a K&N drop-in replacement filter with the stock airbox, or did you install a K&N cold air intake?? if you installed their CAI, check all of your clamps from the air filter to the throttle body, make sure they're all TIGHT so there are no air leaks... the K&N intakes are known for loosening up after a bit...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS LS3, short-throw shifter, NPP perf. exhaust, BMR strut-tower brace, Cold Air Inductions cold air intake, catch-can, ported/polished TB, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old Feb 24, 2011 | 05:25 PM
veselik1's Avatar
veselik1
Default it is just a drop in, should I go to
It is a drop in, should I go to the dealer, or a speed shop?
To check engine light on
