C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
DRive Cycle
Old May 10, 2011 | 08:45 AM
SCRMNC5's Avatar
SCRMNC5
Default DRive Cycle
Hey guys I',m trying to get the vette to pass emissions in my state, I've put the MAF back in the car and the tuner re tuned the car. It's been a week now, and we still can't get all the monitors to read "ready" WTF this is starting to get real aggravating!!!!!!!!!! All i want to do is drive the freakinn thing. Do any of you have any suggestions???
Old May 10, 2011 | 11:08 PM
Old Horsepower's Avatar
Old Horsepower
Try this -
General Motors Driving Cycle
A complete driving cycle should perform diagnostics on all systems. A complete driving cycle can be done in under fifteen minutes.
To perform an OBDII Driving cycle do the following:
Cold Start. In order to be classified as a cold start the engine coolant temperature must be below 50°C (122°F) and within 6°C (11°F) of the ambient air temperature at startup. Do not leave the key on prior to the cold start or the heated oxygen sensor diagnostic may not run.
Idle. The engine must be run for two and a half minutes with the air conditioner on and rear defroster on. The more electrical load you can apply the better. This will test the O2 heater, Passive Air, Purge "No Flow", Misfire and if closed loop is achieved, Fuel Trim.
Accelerate. Turn off the air conditioner and all the other loads and apply half throttle until 88km/hr (55mph) is reached. During this time the Misfire, Fuel Trim, and Purge Flow diagnostics will be performed.
Hold Steady Speed. Hold a steady speed of 88km/hr (55mph) for 3 minutes. During this time the O2 response, air Intrusive, EGR, Purge, Misfire, and Fuel Trim diagnostics will be performed.
Decelerate. Let off the accelerator pedal. Do not shift, touch the brake or clutch. It is important to let the vehicle coast along gradually slowing down to 32km/hr (20 mph). During this time the EGR, Purge and Fuel Trim diagnostics will be performed.
Accelerate. Accelerate at 3/4 throttle until 88-96 km/hr (55-60mph). This will perform the same diagnostics as in step 3.
Hold Steady Speed. Hold a steady speed of 88km/hr (55mph) for five minutes. During this time, in addition to the diagnostics performed in step 4, the catalyst monitor diagnostics will be performed. If the catalyst is marginal or the battery has been disconnected, it may take 5 complete driving cycles to determine the state of the catalyst.
Decelerate. This will perform the same diagnostics as in step 5. Again, don't press the clutch or brakes or shift gears.
Old May 12, 2011 | 01:33 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
If you continue to not get your "readiness tests "set to
"ready" you can have your tuner DELETE all the reporting in your tune to automatically set ALL the tests to "ready"
Then you can have them turned back on or leave it that way-Only issues is if you leave them permanently deleted you won't have any reporting if you have any real sensor failures and the reporting now will be YOU and your input on weather the car is running right or not--
To DRive Cycle
