C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Old school Hypertech programmer III question for my C5?
Old May 31, 2011 | 11:17 AM
Ksths2's Avatar
Ksths2
Default Old school Hypertech programmer III question for my C5?
Hey everyone,
I've got an 02 C5 with tons of mods, heads/cam blah blah, stg 6 RPM 4L60E trans & their stg 3 3.90 diff etc.... I drag race this car 90% street 10%
My question is, i've got a buddy that has an Hyper tech power programmer III and i was thinking of using it to only change my shift points and maybe lower my fan temp switch a bit more but i want to make sure it doesn't screw with my custom Speed inc tune, or shift firmness etc.
All i want to do is raise my shift points a little bit higher for when i'm on motor and on spray.
What do you think?
Old Jun 1, 2011 | 11:09 AM
Ksths2's Avatar
Ksths2
no help at all?
Old Jun 1, 2011 | 02:52 PM
06MonteSS's Avatar
06MonteSS
Supporting Vendor
if your buddy used it to tune his vehicle, you won't be able to use it, because it will be locked to his vehicle...
and if you've got a custom tune done to the car already, you should just contact the person/shop that did the custom tune and have them update it for you....
not sure if you can just change those couple of specific things with that hypertech, and not touch anything else...
I know with a diablo predator you could, but not sure about theirs...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS LS3, short-throw shifter, NPP perf. exhaust, BMR strut-tower brace, Cold Air Inductions cold air intake, catch-can, ported/polished TB, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old Jun 1, 2011 | 03:09 PM
Ksths2's Avatar
Ksths2
i read that in the instructions about the programmer being licensed to a specific vehicle..... so looks like i'm out.
I'd have the tuner adjust the shifts but its 300 miles away, i thought i'd just see if this hand held would do it.
Thanks for the help
Old Jun 3, 2011 | 03:03 AM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Typically the Hyper III will only adjust P/T shift points by MPH--PT shift points are commanded by 2 things 1-throttle position and 2- MPH
At WOT the shifts are commanded again by 2 things but now they are 1--MPH and 2 RPM-- I beleive the rev limit feature on the H-III only works for 6 speed cars and as a safety rev limiter for an A4 and won't adjjust WOT shifting properly--
Old Jun 3, 2011 | 01:36 PM
06MonteSS's Avatar
06MonteSS
Supporting Vendor
yeah, they definitely don't let you do even half as much as a diablo predator/trinity does...
To Old school Hypertech programmer III question for my C5?
