C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Knock Sensor Help!
Old Aug 13, 2011 | 01:38 PM
Painterman's Avatar
Painterman
Default Knock Sensor Help!
Hi Folks; Need help with location and change of Knock sensor 2 (low input) lbank 2 code 332 any help from you guys would be great. You never let me down yet! THANKS.
Old Aug 13, 2011 | 09:00 PM
crainholio's Avatar
crainholio
It's under your intake manifold, you'll have to remove that to access the knock sensor. #2 sensor is the rear one if I'm not mistaken.
Be on the lookout for signs of oil leakage into the knock sensor well...it should be totally dry. If you find oil, you'll need to remove the lifter gallery cover and replace both donuts as well as the gasket.
Be careful squeezing the knock sensor's electrical connector during removal or you'll break it.
Old Aug 15, 2011 | 05:49 PM
Painterman's Avatar
Painterman
Thank you so much!
To Knock Sensor Help!
